Periodic noise triggering motion events BESAFE LBH24S200
vmsguy
Jul 27, 2016
30
1
I have a BESAFE LBH24S200 and I noticed periodic noise showing up about every 7-8 seconds that triggers
a motion event on this camera. This just started in the past week I think. The nighttime temperatures have been dropping
into the 30's, but I wouldn't think that would cause this noise pattern.
YouTube compression makes it harder to see, but at ~2 seconds, 9 seconds, and 16 seconds in the following video you can see the noise kick in for a few seconds then stop.
Any ideas? tonight I'm going to adjust some of the camera setting to see if I can get it to stop.
Brent
Probably just my eye playing tricks but I thought I saw slight movement each time.. windy?
That's not a lot of noise, can you simply adjust the sensitivity of the Motion Detection a tad?
