T Tic Pulling my weight Sep 24, 2016 204 120 Florida, USA Mar 31, 2017 #1 Do I need a crossover Cat6 cable when making a direct connection between a PC and an NVR's uplink port (not PoE port/s)? Thanks.
fenderman Staff member Mar 9, 2014 36,891 21,408 Mar 31, 2017 #2 Tic said: Do I need a crossover Cat6 cable when making a direct connection between a PC and an NVR's uplink port (not PoE port/s)? Thanks. Click to expand... No, crossover cables are not needed in 2017...forget that they ever existed.
T Tic Pulling my weight Sep 24, 2016 204 120 Florida, USA Mar 31, 2017 #3 fenderman said: No, crossover cables are not needed in 2017...forget that they ever existed. Click to expand... So this guide is obsolete? How to access your DVR/NVR without a Router and Access IP cameras directly with an NVR with a Built-in PoE Switch If a crossover cable is used in a setup where a patch is needed and vice versa, will a short circuit occur?
fenderman Staff member Mar 9, 2014 36,891 21,408 Mar 31, 2017 #4 Tic said: So this guide is obsolete? How to access your DVR/NVR without a Router and Access IP cameras directly with an NVR with a Built-in PoE Switch If a crossover cable is used in a setup where a patch is needed and vice versa, will a short circuit occur? Click to expand... The link is reported as malicious by Symantec...regardless, u NEVER need a crossover cable..nothing will happen, try it. Reactions: Tic
T Tic Pulling my weight Sep 24, 2016 204 120 Florida, USA Apr 2, 2017 #6 fenderman said: No, crossover cables are not needed in 2017...forget that they ever existed. Click to expand... Is it because all ethernet ports nowadays are auto-sensing?
