- Nov 20, 2015
- 12
- 0
Hi people, I want to build a pc with which I'll be able to monitor and record the feeds to an HDD from 12 ip cams from various locations/cities in one screen, I'm based in Greece and my budget is around 350/400 euros or 425 US$. The use of this build will be only for surveillance and nothing else, in the above budget I don't include the screen. The PC will monitor and record 24/7.
As I see it (I'm not tech savvy) I need a I3 or I5 intel cpu, a HDD at least 2TByte, I believe a simple motherboard and GPU would be fine?
Any advice would be much appreciated! Thank you
