Have just installed (demo) copy of BI and it is running well on an old Core-I5 laptop with a single HD IP cam.
I'll be running a couple of HD (Axis M3005) cameras and an Axis 241Q with 4 standard res analogue cameras.
What minimum PC spec should I be considering, before I get a licence key and lock it in?
I'd like to use a relatively low power consumption box for 24/7 use. I have a Shuttle PC with a 2.13GHz dual core hyperthreaded Atom and an SSD which I suspect is a bit puny for HD cams.
How about a Core I7 or I5 Intel NUC with an SSD? Would that give me enough headroom to replace the SD cams with HD in the future?
Dermot
Dermot
