I am getting a rack mount patch panel for my NVR but there are so many options out there. I need one that will take CAT6 shielded cable. My cabinet is standard 19" wide. One thing I am not sure about is how the CAT6/network cable coming from Cameras will connect to the patch panel. I don't know if all of the panels have the same connection type, or it varies. Please help clear up this confusion. Since I am using CAT6 cables, being stiff, my concern is, how secure the connection will be at the connecting point to the panel?
I am eyeing on the following one. What are your thoughts? Thanks for your help.
Platinum Tools 24-Port Cat6 Shielded Patch Panel (1 RU) (bhphotovideo.com)
12 Port CAT6 UTP Rack Mount Patch Panel (techtoolsupply.com)
