MY current setup is a 32ch Hik NVR with 3 IP cams connected to one switch on one floor, and today we decided to add the second switch on a different floor level with two more cams.
Immediately I got parameter error when adding the 2 new cams, so I disconnected the first switch and was able to get live view on only one of the new cams.
After failing to add both new cams. We decided to reconnect the first switch and have its 3 cams up as they were more important and now we get parameter error on those 3 cams as well.
I deleted and added and nothing. The cams and NVR are picked up in SADP and can change parameters but live view fails and a constant "parameter error" message.
I hope someone knows whats going on. The only thing I havent tried is to bring the NVR back to default.
Your thoughts? Thanks
