Panoeagle PG-PG2086IRCS-P (dual lens) - option for corner coverage, some thoughts
teredactle
Jan 26, 2020
146
33
CAD
I recently purchased one of these cameras in order to cover my backyard better (180degree coverage); driveway, backyard, pool.
Currently using a WyzeCam3 (midway on shed) and a Lorex LNB8211x (corner of shed). These 2 cover my driveway, backyard as well as the pool, however I wanted something I could put on the corner that could cover it all.
So I got this Panoeagle PG2086IRCS. From what I understand it's cheap chinese knockoff Hikvision product - it's ok for me and my usage.
However, this thing is pretty huge and I really wanted something a bit smaller, hopefully that would fit under the overhang that I have.
I'm thinking of returning it and instead using a Reolink Doorbell (I already have 2, one I use as a doorbell, the other I use inside as the FOV is very wide).
The only problem is that where it's mounted, during the summer there is direct day sun, and the black one I think may melt? :) The white one is in 3:4 mode, which is good for packages (front door), but not good for my intended purpose.
Has anyone found a way to turn the video sideways on these? There is option in the mobile app to flip H or V, but no option to turn 90 degrees...is this possible via some other SW?
Would appreciate some feedback
Thank you
