I seem to have bricked my Panasonic wvsc-385 camera during a firmware update. It stopped in the middle of upgrade, and now I can't access the camera with the default ip address, the address I had set, or the latest configuration tool.I have tried the inital set button several times, hold the button, then applying power for more than 5 seconds, then releasing the reset button.
The green link light comes on and stays on and the orange access light blinks randomly, like something is accessing it.After using the initial set button, I have waited 20 minutes to overnight with no luck.
I am powering it by poe, which has worked with the camera since new, about 2years.I have no power supply for it. The three lights on the poe switch shows it as powered up and connected. I have just the camera and computer connected to the switch to eliminate any other conflict.
I have tried the ip address I set before the upgrade, 192.168.1.79, and the default ip 192.168.0.253 and 192.168.0.10 with no results. I can't ping it either.
Any help would be greatly appreciated.
