PAL video output on BNC ?
artag
Feb 19, 2026
2
UK
I bought a DH-TPC-BF2221-HTM on ebay. Seems in perfect condition, probably never installed.
I was able to get it running through the web interface thanks to a thread here about using edge in IE mode, but I'd like to have the plain old video mode through the BNC connector : I want to pass the output direct to a monitor and this should give me the least lag. I don't see any proper video signal coming out. Just about 0.4VDC, or black level (but no sync). Does it have to be enabled somewhere ?
I'd also like to find a full manual - the leaflet that came with it is a bit minimalistic and there are a lot of settings that aren't explained.
Finally, I'd like to run it from DC power instead of PoE. There's a connector and a specification for this but no adapter, and the polarity isn't shown. I know the central pin positive is very common but confirmation (or a warning!) would be good.
I found 'Web operation manual' which is a great help with general settings on the web interface, but doesn't mention the BNC connector. It does provide some information about RTSP but I haven't yet been able to make it work with VLC (even though there's a specific example !).
What is the URL for RTSP you're trying with VLC?
