G GT60 Young grasshopper Apr 3, 2017 46 14 Jun 28, 2020 #1 Hi a charity I work for has had a camera vandalised with paint unsure what type of paint was used. Any idea of what can safely remove the paint? Thanks
CCTVCam Known around here Sep 25, 2017 2,875 3,759 Jun 28, 2020 #2 It might help to specify the type of camera as the type of material covering the lens ie polycarb or glass may affect the options also. Reactions: GT60
G GT60 Young grasshopper Apr 3, 2017 46 14 Jun 28, 2020 #3 CCTVCam said: It might help to specify the type of camera as the type of material covering the lens ie polycarb or glass may affect the options also. Click to expand... I will find out and get back to you Thanks
G GT60 Young grasshopper Apr 3, 2017 46 14 Jul 1, 2020 #4 Apparently the CEO cleaned the lens and is getting the CCTV installer in to check. But thank you for your help
