Owsoo NVR16 Problems
KD2DXF
Sep 16, 2018
2
Upstate, NY
hello all, new here.
I have an Owsoo branded 16 channel NVR. I cannot get this to properly connect to my router. If I issue a static IP within my local IP range, it shows as offline, But when I enable DHCP, it will show online, however it somehow gets an IP that is completely outside of my local IP range. but i can still access it using either ip on my local network. I have ports forwarded, but i cannot access from WAN no matter what configuration i use
Also seperate from this, I read that you can update the firmware from the manufactures website, however i cannot distinguish with file i need for the 16 Channel NVR.
Any help is appreciated
