Outdoor junction box
harleyl7
Pulling my weight
Jun 4, 2021
265
225
What is everyone using to store Poe switches outside? I can probably find something at a hardware store, but wanted to see if anyone had a good option.
The box would hold a unifi flex with one conduit pipe leading to it with the main line.
Sent from my SM-G781U using Tapatalk
a google search turns up this one, not sure if it's avaliable in your area though.
I had seen that and for the price, I'm not sure if I need the extra power unit thing that comes with. My main switch should be enough to power 2-4 cams put of it along with the other 2 cams installed off the same switch.
Actually it's really not priced that bad tbh. But might be able to find just a decent junction box and rig some stuff up
Just search "weather proof equipment enclosure" on Amazon.
I was going to use one of these, but haven't gotten around to it yet. I have a Rachio Sprinkler Controller already and I think the outdoor enclosure would work great
$30 and it has an electrical outlet inside (lower left corner - outlet faces up)
Oh those do look nice.. might have to try one out for sure.
That ranchero box isn't waterproof.
Reactions: sebastiantombs
