Outdoor grade POE injectors
rufunky
Pulling my weight
Dec 2, 2015
707
248
I'm looking for a good, outdoor grade Poe injector that will fit inside a parking lot light post. Does anyone have any suggestions?
Look for 'industrial' type POE Injectors, which can operate over a larger temp range.
Good example here.
what's the application? sounds like you have power and ethernet at the pole already, correct? if so, why not inject the PoE at the ethernet head end (at the switch)?...
Reactions: aesterling
The plan was to run a cat5 from the camera to a POE injector for power then a cat5 tail to temporarily connect a laptop to download recorded video when needed.
