Hi,
I want to install a total of 4 outdoor IP cams at my house. 1 on each wall. For this, I am looking for recommendations.
Rough use-case/requirements:
assumptions (hints are welcome):
Thanks for your support!
Max
- wall-mounted
- outdoor
- mounting height ~5 m
- max. viewing distance 25 m
- hFoV ~30° on 3 of the 4 sides and ~115° on the other side of the house
- wiring option: CAT7 with PoE
- in order to avoid discussions with neigbours a bullet cam might be preferred
- no color image required during night
- IR illumination
- ONVIF
- 4 Mpx should be sufficient
- PTZ not required
- microphone not required
- fancy AI features, e.g. face/object detection not required
- fixed focus is sufficient (tbd)
Max
