Outdoor 4g poe router?
rufunky
Pulling my weight
Dec 2, 2015
707
248
Does ubiquiti ( or similar quality ) make a an outdoor 4g poe router?
I use teltonika, I don't think they have a poe version but I've installed them on various boats. The routers have a lot of useful features and I use a reboot at 3:00am as one boat is in a poor coverage area and I have never had an issue with it.
Simply add a poe injector or switch as required.
FYI, I have a poe injector installed on this system to power a ubiquiti bullet which picks up local wifi networks in visiting marinas to give me a dual wan setup.
Reactions: rufunky
Thanks, I will check them out. My biggest issue is finding a power source ( POE or DC ) that is ip67 or higher rated. I tried to get away with a standard POE wall wart and an in use cover over a receptacle but that didn't last long...
