- Dec 18, 2014
- 23
- 0
Hello!
I'm using the highly recommended Hikvision 2432, which I'm very happy with.
I've set it up as a baby monitor and it's working great so far. The only caveat is I've noticed viewing the live video feed can be quite expensive in terms of CPU usage. Running VLC on my macbook it's using roughly %50 CPU (using the RTSP stream) and when using a baby monitoring client on the iPhone it drains the battery really quickly and the phone gets really hot. I'm going to assume that this is because decoding happens on the CPU and is very expensive.
Since this is only being used as a baby monitor, I figured I could probably lower some of the video quality settings, but I wasn't sure which would be best to tweak with. I currently have it set to 720p at 25fps. Would highly appreciate your recommendations
