Not sure how far away the LPR area is from the cam in that picture. As
@wittaj stated, one cam to do all of your listed items is not going to work. LPR must have a dedicated cam to get plates both day and night. It needs to be focused on the path of the vehicle. A diagram/map view of this area may help in giving you recommendations. Without distances, the Z4E may not have enough zoom/FOV to get plates there.
If you want info on driver/vehicle id you will need a second cam that is tuned for that job. That cam may be able to give you info on animals and pedestrians.
See the LPR section of this forum.
My LPR cams are 3 feet off the ground. My overview cam is 7 feet off the ground. See these threads.
	Thought I would throw together a post on my experiences so far with LPR in an effort to help others that are considering running down that rabbit hole. There are some practical considerations you should know about LPR. I am approaching this from the position of using
Blue Iris and Plate Recognizer Snapshot as that is what I have done so far. If you are using an NVR or some other plate OCR, then some of the discussion may not apply to you.
Plate Recognizer (PR) is very easy to set up in Blue Iris (BI). It uses the Alert image from the trigger alert in BI. BI sends that Alert image to PR...
	Introduction
This thread is about my journey into LPR (License Plate Recognition) after having about 18 months of experience with IP cams and having quite a bit of my system finished. I am not an expert on LPR, or IP cameras either. But I have spent a lot of time working with my system and interacting on IPCAMTALK.
Some things to realize as you read this. I am retired so I have time to not rush the work and I do it all myself. This took almost a year from inception to working cams. Part of the reason is that both my wife and I had some medical issues and both had surgeries during...
	We were out of town and I was checking my cams remotely one morning and noticed one of the Deputies that regularly patrol my subdivision had been at my front door. She has come to me a few times requesting video as she knows I have fairly good coverage of the streets at my corner. I noticed that as she walked down my walkway, she stopped and picked up something on my lawn. Since I knew her, I sent an email asking what was up. She replied later in the day that there had been an incident in the neighborhood and wanted to know if I had video from the night before.
I answered her that I was...
	I have been into cams as a hobby now for a little over two years. I originally had hoped to do LPR, but as time went by I thought it would never happen, mostly due to where could I put cams and how to get cable to them.
But then COVID hit and I found I had a lot of time on my hands just sitting around on my ass on the front porch. Which got me to thinking about LPR again. So I made a plan and tested multiple ideas. Finally bought the cams, built the box and installed them. Got everything hooked up this past Tuesday. Thanks to all of the folks that came before me and did the hard lifting...
