Optical performance comparison SD49225T-HN vs SD59225U-HNI
Dave Lonsdale
Pulling my weight
Dec 3, 2015
460
195
Congleton Edge, UK
Has anyone been able to compare these two PTZs? Clearly the 49225 hardware will be less capable, for example the 49225 doesn't support 1080p in stream 2, but I use BI and don't need autotracking etc. The key parameter for me that appears to be different is the S/N ratio - 50dB for the 49225 and 55dB for the 59225. (Other starlights also have a 50dB S/N). Would I see a difference - for example, more smeared motion when its dark?
Aslo, the early 59225 specs state the 'Exmor R' image sensor but both now state 'STARVIS' which I believe is a slightly better Exmor R, perhaps even selected out of the same production line. So, was the STARVIS sensor introduced after a build date?
