Hi. Really hoping to get some experienced opinions on this setup before I pull the trigger. We recently moved into new construction at the edge of a very large development (~1000 units in 15-20 subdivisions). Our property is on the corner of the last side street before a dead end at the edge of the development. We soon noticed a trend of "lurkers" driving down the dead end, parking for 1-5 minutes, then taking off down the main drag heading out of the subdivision. This happens multiple times per day and I don't have a clear line of sight to the end where they park. Some others are using the dead end as the starting line of a racetrack and then come flying out. Neighbors often comment about the lurkers on our neighborhood Facebook group and we're the lucky ones in closest proximity. We're 2.2 miles in from the main road so police never patrol the area. Then about one month ago my neighbors left their garage door open and it was burglarized at around 8pm. They noticed a car parked near the house for a few minutes barely within view from the front windows which then sped off, after which he found that several power tools and some small landscaping equipment was taken. His Ring camera didn't trigger or record anything and he speculates the thieves used a deauth attack to knock wifi devices off line long enough to be in and out. That's when I started looking into wired cameras.
I'm looking to start off under $1000 with the following 4 cameras, each with a certain goal. PPF data comes from the IPVM FOV calculator. Cameras will run 24/7. I have attached a rough sketch of the camera angles on my property for reference.
1) Dahua IPC-HFW5231E-Z5 ($197): 2MP Starlight varifocal 7-35mm. H.265&H.264 triple-stream. ONVIF compliant (no specific profile stated)
The target area is 95-100' diagonally from the SW corner of my house to catch license plates driving out from the dead end and/or those turning out from my street in the same direction. Just want to be able to read plates, not looking for a full LPR setup. IPVM shows 65PPF at 100' with a 30' wide FOV. From what I've read 65PPF should be adequate for most plates. There's a well-placed streetlight which should help with night viewing. (Contingent on finding a NTSC version of this camera. The product page is for PAL)
2) Lorex (very open to alternatives) LNB8973BW ($199): 8mp 1/2.5 sensor, varifocal 2.8-12mm. ONVIF S/T. H.265 / H.264 / MJPEG.
My intent here is to see cars and foot traffic heading down the main drag to/from the dead end. The street runs perpendicular to the south side of my house. I want a 4k camera for clear daytime images and discernible night images up to 70 feet away with a somewhat wide FOV. The streetlight is right above this area and will improve night vision. I'm concerned 4-5MP cameras won't provide the PPF to recognize/identify at 70 feet. IPVM shows 55PPF at 70' distance with a 70'wide FOV when zoomed in to 53 degrees. This can be further tighened to 39 degrees for 77PPF with a 50' wide FOV at the same 70' distance. This Lorex is the only varifocal 4k camera I can find within my price range (trying to stay under $200/camera) but again I am very open to any rebranded 4k varifocal Dahua turret or bullet for this function.
3) Two Loryta IPC-T2431T-AS ($80 each): 4mp 1/3 "starlight" 3.6mm 1.6 ap turret cams with mic. ONVIF S/G. H.265; H.264; H.264B; MJPEG.
One for the front of the house overlooking the driveway and entryway, distance to the street is 30'. The other is for the rear of the house facing the backyard which extends 40' before a steep dropoff. These starlight cameras produce 50 PPF at 30' distance with a 54'w FOV. I will eventually add two additional cameras (one front, one back) after I see how the T23431T-AS performs in both applications.
4) Dahua NVR4208-8P-4KS2 4K 8 Channel PoE NVR ($259): H.265/H.264 decoding; Max 200Mbps Incoming Bandwidth
WD Purple 4TB hard drive also needed ($101)
I'll add more cameras in the future but for now this seems like it will meet my needs. The total cost for this setup is $836 without shipping, CAT6, additional mounting hardware, etc. Please let me know if you see any obvious flaws in my thinking or if you know of a better option for either of the varifocal cameras that will get the job done at 70' and 100'. Those two views are my priorities right now: the road leading to/from the dead end and the diagonal corner where I hope to catch plates. Thank you in advance for any feedback! I'm attaching a very rough overview map made with snippets from IPVM and Google maps. There's no satellite image for my property yet so took a snip of cameras arranged around another house in my neighborhood using the IPVM map and then "moved" it to my property. It's crude but very close to scale.
