Opinions on my IPC-HDW5231R-ZE at night
Sybertiger
6,169
20,201
Orlando
Seeking comments on several different settings for this cam at night. Thinking about adding an IR illuminator to increase quality of pic but wanted to know what you think about it "as is" with a couple different settings.
IR turned off
IR on Manual 0% (should be the same as OFF)
IR on Manual 1%
IR on Manual 100%
Uplighting turned off...IR off
SmartIR
5 Minutes after Sunset
@Sybertiger, what's your goal with this camera? Is it an overview cam for this side of your yard?
The purpose for the wide FOV (adjusted to 4mm?) is to get an overall view of what's going on at that side. On the left side you can see the edge of forested wetlands so the intent is to see any approach that "funnels" unwelcome people or animal towards the backyard. ID quality would require getting close to the cam. Nighttime is a challenge and I note that a full moon is near. We'll see what it's like with no moonlight.
I'll have a 4MP Starlight+ mounted on the side yard soffit near the front of the house soon. Andy is sending a replacement for a defective one.
A PTZ would be sweet to have on that side but wow, those things cost a lot.
Try moving that landscape tree up light to the far side of the trunk so it's hidden behind it in regards to the camera view.
Yeah, it's unfortunate the position of the cam versus the tree uplighting. The tree lights have been there a decade and are on a pipe pounded in the ground...not easy to move.
I'll turn them off and get a snapshot tonight to compare the difference with and without uplighting.
A still shot at night tells you nothing. You need to see how it does with someone walking through the FOV.
I did a little bit of that last night but it was too cold last night (50 degrees LOL) so I stopped. I'm clearly going to have to play with the cam settings....had "ghosting" blur when near the cam then also IR overexposure that prevents identifying faces up close.
After living in the Midwest all my life I'm more like the bottom picture (not exactly ofc), but it is weird that I still have loads of snow on my yard and daily highs have been over 40 for at least a week.
I recently traveled to Las Vegas, and the cabby was concerned I might get a cold, travelling from airport to hotel. It was 50 at like 8PM at night, she had a jacket over top of a sweater on.
