I'm working to securely and remotely monitor my Dahua cams via the DMSS app, when I'm away from my home network. I read that the right way to do this is through a VPN connection. I have a TP Link router that has an OpenVPN server option. I created a certificate, enabled the VPN server, and exported the configuration file.
Then on my iPhone, I installed the OpenVPN client app, and attempted to load the OpenVPN profile that I exported. It does not load/connect and I get a message of "There was an error attempting to connected to the selected server."
Here are my OpenVPN server settings on the router:
I suspect it's something really simple/easy to fix, but unfortunately I'm not that knowledgeable on this stuff, even after a lot of reading and research. Looking for some help. Thanks.
