- Apr 25, 2018
- 119
- 47
So I followed this link from @SouthernYankee
Randy : OpenVPN on a Asus router
And all set up.
But the OpenVPN Tunnelblick client on my OS gives me the following errors:
Warning: This VPN may not connect in the future.
The OpenVPN configuration file for 'client' contains these OpenVPN options:
• 'ns-cert-type' was deprecated in OpenVPN 2.4 and removed in OpenVPN 2.5
• 'comp-lzo' was deprecated in OpenVPN 2.4 and has been or will be removed in a later version
You should update the configuration so it can be used with modern versions of OpenVPN.
Tunnelblick will use OpenVPN 2.4.6 - OpenSSL v1.0.2q to connect this configuration.
However, you will not be able to connect to this VPN with future versions of Tunnelblick that do not include a version of OpenVPN that accepts the options.
Has anyone seen this?
ALSO
I have a VPN client already (NordVPN) - so does this mean I can't use it???
And all set up.
ALSO
