Netwalker
- Aug 8, 2017
- 46
- 28
I thought you did not need to port forward with VPN. Both links suggest port forwarding?
Yes, if the vpn server isn’t on the router, you’ll have to use port forwarding in order to let the router know where you want data from that port sent to.
In this case it’s only going to be the port for the vpn connection. The BI ports or anything else you may have inside your lan are still blocked from wan access, but can still be accessed using the vpn tunnel.
