Onvif triggers creating multiple alerts version 5.8.8.8
CamCrazy
Getting comfortable
Aug 23, 2017
932
789
UK
Hi, on my previous older 2022 install the onvif triggers would simply create one alert in Blue Iris, the new version on a couple of cameras seems to create 2-4 alerts for the same event. Sure this is something simple which changed, seems to be occurring with the RuleEngine/LineDetector/Crossed
Guessing this is due to higher sensitivity or similar with this newer version, maybe less extensive lines are required under IVS rules now?
Thanks
