Hi guys. Forgive me if I have posted this in the wrong section. I have just joined here and have a couple of questions. I have a cheap floodlight cam that uses the ipcam360 app. Even though this is onvif, the camera uses UDP protocol instead of TCP. There is no way to change this, and my cheap Chinese NVR (xmeye type) does not seem to have UDP, but only TCP and fails to connect. This is the only camera ift ails to connect to.
If I use software such as Tinycam pro, and other software I have that UDP option and can get the cajwra working
My questions are:
Is there a way to enable UDP on the Chinese NVR? Do other alternative NVRs have this option?
Is there firmware for the ipcam360 (I can provide more details on the camera)
I know I could purchase another/better camera, but just wondering if there is a work around. Was also thinking in the long run to buy a low powered pc and use that as an NVR instead.
Look forward to hearing your comments kindest regards Matthew UK Wolverhampton West Midlands
My questions are:
