- Nov 1, 2014
- 1,832
- 1,193
I been using NVR for some time but with the recent changed from one of the cam manufacturing that seems to keep screwing up the notification features when they make changes to the phone apps at each update so I am thinking about looking at other resources to use for notification and alert.
Only main reason I never gotten into using a computer as an NVR due to the size of the unit and I am trying to cut back as much electricity usage as possible since a NVR would need to be stay on 24/7 without sleeping correct?
I understand the need to use big processor like i7 due to the video compressor required to process it but I am wondering if Blue Iris can be trigger via camera ONVIF setting without needing to stream the video so it can be install on smaller computer like mirco size computers? I just wanted to use Blue Iris to notify me when a motion is detect but not to stream video to it or to record videos. Is that even possible?
I know that IVS probably will not work since it not available via ONVIF and the motion detector on camera sucks so I am guessing to have a good motion detect that Blue Iris the one that need to do the analyzing and still require a high end processor right?
