Hi!
I have a situation with two barriers that I would want to open with one camera using ANPR.
The cars will come on the same road, and I want to open the first or second barrier depending on their license plate. I'm trying to read the manuals and instructions, and it seems like it would be possible with a camera with two digital outputs. Can I create one whitelist for barrier one, and trigger output 1 if a license plate matches, and then a blacklist which would trigger alarm output 2 if matched which would open barrier 2.
I wont use a NVR, only the camera. Would this work? I.e with this camera: iDS-2CD8A46G0-XZ(H)S(Y)
