one camera file can not be found on playback
Sep 19, 2015
1,143
1,484
Naples Fl
I tried deleting the camera and reinstalling it, check the settings against the other cameras, and on playback It randomly get that error message and other clips will randomly play back at what looks like 8X speed
post your record tab settings
these settings are profile specific...are you using more than one profile?
no just one till I learn how to set up more profiles
the odd things is I had 2 replace 2 cameras and set them up the same way, and they are fine, but that camera is not. one video is played back normal, the next at a higher speed and the next file is not found.
what exact version of blue iris are you using? try rebuilding the database.
post the video settings configuration tab for the problem camera. What model is it? post the video settings from the camera itself.
NSC-274S-DMZ
