One cam showing substream instead of full when selected from BI console
Mike A.
4,210
7,094
One of my cams, that I've had running for a long time with no changes, today displays the substream when selected from the BI console. i.e., It doesn't switch to full stream when clicked on. Live view direct from the cam is the full stream and fine. UI3 works as normal. BI stats show running numbers that would be right for the full stream (4.1MP, 15/1 fps, 1021 kB/s) so I know that it's seeing that stream. But it won't switch over and display it.
String in video setup is correct. Tried restarting the cam. Closed and restarted the BI console. Stopped and restarted BI service. Rebooted BI server. Still the same.
Any ideas?
Delete and re-add camera in BI ? :idk:
I was about to and then thought maybe try copying it first. That worked. No clue... :idk:
Reactions: TonyR
Substream Demons
Reactions: Mike A.
I had a camera do the same thing. If you right click on the camera for the menu there's a selection for "main stream when solo/full screen". I kept overlooking the arrow down button in the menu so I couldn't find it for the life of me. Then I was like oh, I'm a dumdum.
