My surveillance product vendor's supplier, Ameta Group, is very difficult to communicate with, even through the vendor. I ask a question and rarely get an answer. Usually it goes into a black hole unless I am annoyingly persistent, and then it's usually a non-answer like "we'll get back to you", or "give us access". I once tried calling them directly and they were rude and dismissive. If I can say it right now, you are better off buying an authentic Dahua system rather than saving a few bucks on an OEM knockoff.
I just pushed the latest OEM firmware and see that they significantly changed the UI design as of version 2024-05-08. Now the fonts and icons are disproportionately large and do not fit within the UI properly. The left nav bar titles are so large that they don't fit across the display (i.e. truncated and unreadable) unless I zoom the web page to 50%. Icons are much too large and are clipped by the lower screen boundary. Textfields and checkboxes are misaligned. Chrome and Microsoft Edge exhibit the same results. Yes, the playback plugin is installed, but that didn't help the layout. And that reminds me... I should monitor outbound traffic with wireshark (from that plugin) to ensure whoever wrote the firmware isn't exfiltrating data.
It appears they are trying to replicate the look/feel of the physical console, and I do appreciate it. They've added some nice features such as the ability to see multiple video tracks, synchronized playback, and a nicer clip-export feature. The time bar still cannot be scrolled or zoomed despite Dahua adding this feature in their latest firmware. I was really hoping for that feature.
The latest firmware for my particular Dahua OEM (DBase) NVR is 2024-10-18. Has anyone else had a different, better experience? If so, how?
If I could get my hands on the original source code for this OEM firmware, I would make the necessary changes to the UI to fix the proportionality issues, possibly add zooming via mousewheel to start, then publish the improved source on GitHub.
So... I would like to open the discussion by asking: Does anyone here know if there is an OEM firmware available from which we (I) can start working on an inproved version? Are any of you employed in the OEM consumer surveillance device manufacturing industry who also happens to have access to such source code?
It's a long shot, but thought I'd ask. I think I'll also call Dahua and see if I can get my hands on the base firmware through the developer program (if such a thing exists.)
Torin...
Torin...
