Hello.
I cannot prevent excessive CPU spikes on the NVR616-128-4KS2 model Dahua recorder, I wonder if we have friends who have experience in this regard?
The recorder is updated to the latest version.
2 MP standard cameras were used Main Stream Bit Values fixed at 2048. I reduced the Sub Stream Bit Values to 512, but I did not get any results.
At the same time, there is a Raid 5 disk structure in the recorder, when I disable the disks, the CPU decreases up to 40%. Do you have a solution suggestion?
