Nvr5832-4ks2 BIOS
Jul 7, 2021
14
4
Tehran
Hi everybody
i need BIOS of Nvr5832-4ks2 dahua
Pls send for me
Tnx
Label in photo
OK - I think I understand.
You are looking for a full dump of the NVR flash storage.
The rt809h is a flash programmer - have you used it on the NVR flash and corrupted it?
Ohhhh come on man
Yes iknow There is no need to explain about rt809h. I know what this device does because I have been using it for many years and now I just wanted the nvr 5832 4ks2 dump bois file. If you have it, can you help and send it to me. I am a Dahua engineer.
I have been using RT809H for many years Now I only want the NVR 58324ks2 dump BIOS filefor sop48 nand bios , I have the BIOS of other models, but I don't have this BIOS and it doesn't fit.I have several BIOS dump files of this NVR 5XXX 4ks2 dump files, but it does not fit this version or PN. I am an electronic engineer with several years of experience Now, I just wanted the BIOS of this model. If you have one, please send it to me. I would appreciate it tnx alot/.
The comment was for the benefit of others.
Clearly you would know what it is ...
Sorry, I would if I had it, but I don't.
probably stole an NVR and is trying to gain intelligence from it.
Reactions: [email protected]
