Need some help from the forum, I got this Nvr that was not booting some lights turn on on the board no network light on ethernet port and when connecting to tftp server the console just displayed a cursor jumping on the screen.
I managed to flash the primary bootloader with the CH341A programmer and this is what I have on the console now
Spi(cs1) ID: 0xEF 0x30 0x13 0x00 0x00 0x00
Special NAND id table Version 1.36
Nand ID: 0xEF 0xF1 0x80 0x95 0x00 0x00 0x00 0x00
stmmac_init,688,0x70431,3
MAC: 00-00-23-34-45-66
After this I flashed the bootloader
hisilicon # run da
get phy id:0x70431
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Download Filename 'u-boot_spi.bin.img'.
Download to address: 0x80004000
Downloading: *#################################################
done
Bytes transferred = 310256 (4bbf0 hex)
boottype=0:
dh_wdt_stop called
flash_do_flwrite,646,ret:-29,flash_sn:0
Header CRC Checking ... OK
Data CRC Checking ... OK
Image Name: NVR5XXX-4K
Image Type: ARM Linux Firmware (gzip compressed)
Data Size: 310192 Bytes = 302.9 KiB
Load Address: a0000000
Entry Point: a0080000
Programing start at: 0xa0000000
write : 0
write : 0
write : 33
write : 66
write : 100
done
Erasing SPI flash, offset 0x00060000 size 128K ...done
Writing to SPI flash, offset 0x00060000 size 128K ...done
dh_wdt_start called
This is my printenv
hisilicon # printenv
bootargs=mem=96M, console=ttyAMA0,115200 rootfstype=cramfs root=/dev/mtdblock1
slave_bootargs=mem=64M console=ttyAMA0,115200
bootdelay=1
baudrate=115200
bootnandflash=0
key=000000000000
deviceid=0000000000000000
ethaddr=00:00:23:34:45:66
eth1addr=00:00:23:34:45:77
ver=U-Boot 2010.06-svn3003 (Dec 10 2017 - 23:35:02)
netmash=255.255.255.0
gateway=192.168.1.1
loadaddr=0x80004000
boottype=1
bootcmd=usbupdate
filesize=4BBF0
fileaddr=80004000
gatewayip=192.168.1.1
netmask=255.255.255.0
ipaddr=192.168.1.108
serverip=192.168.254.254
sysbackup=0
da=tftp u-boot_spi.bin.img; flwrite
dr=tftp romfs-x.squashfs.img; flwrite
du=tftp user-x.squashfs.img; flwrite
dw=tftp web-x.squashfs.img; flwrite
dl=tftp logo-x.squashfs.img; flwrite
ds=tftp slave-x.squashfs.img; flwrite
dc=tftp custom-x.squashfs.img; flwrite
up=tftp update.img; flwrite
tk=tftp uImage; bootm
pm=tftp 575s_PMX.img; flwrite
dx=tftp u-boot_slave.bin.img; flwrite
db=tftp u-boot.bin.img; flwrite
restore=0
stdin=serial
stdout=serial
stderr=serial
verify=n
Now when I run dr or run up fails to write like this
hisilicon # run dr
get phy id:0x70431
Download Filename 'romfs-x.squashfs.img'.
done
Bytes transferred = 26099776 (18e4040 hex)
boottype=0:
dh_wdt_stop called
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 26099712 Bytes = 24.9 MiB
Load Address: a0700000
Entry Point: a2100000
Programing start at: 0xa0700000
write : 0NAND read from offset 700000 failed -74
NAND write to offset 700000 failed -5
write flash error
dh_wdt_start called
hisilicon # run up
get phy id:0x70431
Download Filename 'update.img'.
done
Bytes transferred = 41767576 (27d5298 hex)
boottype=0:
dh_wdt_stop called
flash_do_flwrite,646,ret:0,flash_sn:0
Data Size: 340488 Bytes = 332.5 KiB
Load Address: a0200000
Entry Point: a0300000
Programing start at: 0xa0200000
write : 0NAND read from offset 200000 failed -74
NAND write to offset 200000 failed -5
write flash error
Data Size: 3850720 Bytes = 3.7 MiB
Load Address: a0300000
Entry Point: a0700000
Programing start at: 0xa0300000
write : 0NAND write to offset 300000 failed -5
write flash error
write flash error
Data Size: 108176 Bytes = 105.6 KiB
Load Address: a2100000
Entry Point: a2200000
Programing start at: 0xa2100000
write : 0NAND read from offset 2100000 failed -74
NAND write to offset 2100000 failed -5
write flash error
Data Size: 2395936 Bytes = 2.3 MiB
Load Address: a2200000
Entry Point: a2500000
Programing start at: 0xa2200000
write : 0NAND write to offset 2200000 failed -5
write flash error
Data Size: 5509184 Bytes = 5.3 MiB
Load Address: a2500000
Entry Point: a3300000
Programing start at: 0xa2500000
write : 0NAND write to offset 2500000 failed -5
write flash error
Image Type: ARM Linux Standalone Program (gzip compressed)
Data Size: 3432448 Bytes = 3.3 MiB
Load Address: a3300000
Entry Point: a3800000
Programing start at: 0xa3300000
write : 0NAND write to offset 3300000 failed -5
write flash error
Data Size: 4096 Bytes = 4 KiB
Load Address: a3800000
Entry Point: a3a00000
Programing start at: 0xa3800000
write : 0NAND read from offset 3800000 failed -74
NAND write to offset 3800000 failed -5
write flash error
Data Size: 12288 Bytes = 12 KiB
Load Address: a3a00000
Entry Point: a3c00000
Programing start at: 0xa3a00000
write : 0NAND write to offset 3a00000 failed -5
write flash error
Data Size: 13824 Bytes = 13.5 KiB
Load Address: a3f00000
Entry Point: a3f40000
Programing start at: 0xa3f00000
write : 0NAND write to offset 3f00000 failed -5
write flash error
flash_do_flwrite,704
dh_wdt_start called
hisilicon # run da
get phy id:0x70431
done
boottype=0:
dh_wdt_stop called
write : 0
write : 0
write : 33
write : 66
write : 100
done
dh_wdt_start called
This is my printenv
bootdelay=1
baudrate=115200
bootnandflash=0
key=000000000000
gateway=192.168.1.1
loadaddr=0x80004000
boottype=1
bootcmd=usbupdate
filesize=4BBF0
fileaddr=80004000
sysbackup=0
restore=0
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon # run dr
get phy id:0x70431
done
boottype=0:
dh_wdt_stop called
write flash error
dh_wdt_start called
hisilicon # run up
get phy id:0x70431
done
boottype=0:
dh_wdt_stop called
write flash error
write flash error
write flash error
write flash error
write flash error
write flash error
write flash error
write flash error
write flash error
write flash error
dh_wdt_start called
