Anyone know the procedure to hard reset this model using the button inside? A customer of mine misspelled his email address then lost his password, so it is sending an unlock code into the abyss if I use gdmss to try and reset the password.
Not sure how the reset button works. If I hold it then power on the unit, let go after 30 seconds, nothing happens. If I hold it until the nvr is fully booted up, nothing happens
Of course dahua ignores your emails if you send the qr code security string to [email protected]
