My Dahua NVR is located in a location which is impossible to run Ethernet cable to my router. So for the past 2 years I have been using an old Linksys WRT54G router with DD-WRT firmware configured as a wireless bridge to my router. This has been working great with more bandwidth and speed than required by the NVR. With all of the other WiFi connection in the house, it would be nice to reduce this number if possible.
Since my house is cabled with RG6 coax, and I do have a MoCA (Multimedia over Coax Alliance ) mesh network configuration setup throughout the house I decided to retire the Linksys router and hardwire the NVR on to the network. All of the coax cabling meet in the attic where the multimedia amplifier and splitters are located and is nicely directly above the NVR. So I purchased an Actiontec ECB6200 Bonded MoCA 2.0 gb Ethernet network adapter, ran a short distance of RG6 through the ceiling down in the wall to the NVR. I had swapped out on of the 2 way coax splitters to a 3 way splitter for the extra coax connection. I Connected everything together and system is up and running! I ran some speed test and there really isn't any difference between the wireless bridge and MoCa connection.
Now I have one less WiFi system on my wireless system.
