I have a Hikvision DS-7608NI-Q2/8P NVR that I want to install my POE ip cams to through a POE switch (currently using a trendnet TPE-S50). The NVR is connected to my TV via HDMI and I do not want to run up to 8 cat5 wires to the NVR but instead rather connect the ip cams to the NVR through the POE switch in the attic.
I prefer using the Hikvision plug-and-play feature vs the manual entry of the cameras on the network, which this only seems to work by connecting the NVR to the POE Switch. Test camera I am using is a DS-2CD2142FWD-I 4MP.
Question is: to connect the NVR to the network can I additionally connect the NVR LAN to one of the POE switch ports?
