- Oct 11, 2014
- 182
- 44
Per Fenderman's recommendation on PCs, I picked up a Dell Optiplex 9020 with i7 Haswell. It's been sitting on the floor unopened. I'm at the end of the return window and called Dell to get RMA and label. They were very nice about it, almost made me feel bad to return it.
I'm sure there are other NVR vs PC threads. I've read about more flexibility with Blue Iris. The NVR works just fine for what I need, but maybe I don't know what I'm missing. Kind of like in the early days of a DVR, didn't quite expect the impact of that device. I dpn't do notifications and not sure I would even with blue iris.
2nd monitor:
Primarily, what I would like to do is display the cameras across multiple monitors, in other words one monitor shows 4 cameras and another monitor shows additional cameras, say cameras 5-8. The NVR offers 1, 4, 6, 8 and 9 images per monitor but I like the quad view due to the size of the images. Any more than 4 images and they start getting too small and/or different sizes.
Security:
What else am I missing?
Thanks.
2nd monitor:
- Maybe a bigger monitor is the way to go? I currently use a 24" monitor fed directly from the NVR.
- Or add another NVR for the other 4 cameras? (more watts,
) - Does the PC with BI have an advantage over an NVR (Hikvision 7608 with 8-channels of POE) in this regard? My understanding is you want to use the on-board graphics, so 2 or more monitors is out.
Security:
- Being as I can't "see" the cameras behind the NVR, does that make the cameras secure?
- If I use a PC, are the cameras secure like on the NVR if I home-run them to the PC?
- If i put them on my LAN using local POE or power supplies for each camera, am I at risk of hacking?
- Under which scenarios do I need to keep camera firmware up to date?
Thanks.
