I had a call from a customer recently to say the she was having issues with Playback, I attended 2 days later and the HDD symbol was solid red on the front of the NVR (So I was assuming this was a Hard drive Issue), but also in the meantime, she had lost display on the Local Monitor.
I tried the trusty On/Off - Nothing, although the Hik Loading Screen did appear, this followed with a blank screen showing only the mouse pointer, which was responsive.
I then tried to locate the NVR on SADP, to which it was showing and also active (All looked normal). I click the Hyperlink and get ''this site cannot be reached / Refused to connect'' from the browser.
I ping the NVR - which is successful.
I bring the NVR back to my office, to try with another monitor, same result as above. I then load up IVMS, the NVR shows in Online Search but then once added, shows ''Device'' in Device type (Rather than the usual ''Encoding Device'') and also shows as offline. Serial Number also doesn't show.
NVR: DS-7732NI-K4/16p
Software Version: V4.71.005build 220524
Looking for any ideas/help that I can get?
