Hi everyone,
I am looking a setting up a surveillance system from scratch that will comprise of about 25 Cameras. I will utilise the Hikvision DS-2CD2332-I 3MP camera in most locations with various lens sizes depending on what is required. I may install some long range cameras with 20X Optical zoom, this is TBA. There are 3 Buildings with each getting some cameras. All the buildings are in close proximity to each other. The largest distance from the front building to the back one is about 60-80m.
I am tossing up between running one NVR capable of running all the cameras, running 3 separate NVRs (one for each building then port forwarding the NVRs to a computer that can monitor all the NVRs connected cameras) or putting together a server/computer with
software like Blue Iris or using the Hikvision iVMS-4200 v2.3.1.3 or Hikvision iVMS-5200 Professional software.
I need something that is easy to operate as I will not be on the site to configure or watch over it. I like the idea of Blue Iris because it seems feature rich and capable, with a very low cost at $60 for up to 64 camera license. A single NVR capable of running this amount of cameras will cost about $3,000 and from what I have read are not the most user friendly, GUI isn't so good/clunky and very limited.
Any suggestions would be great.
TIA for your ideas/advice!
