F faran n3wb Jun 7, 2019 5 0 Swindin Jun 13, 2019 #1 If i was to hard reset the nvr by exporting the XML file.. Sending this to my seller will this also reset the passwords for all camera. I have the following NVR NVR DS-7608NI-K2 / 8P Firmware Version: v3.4.104, Build 190128
58chev Pulling my weight Aug 30, 2017 300 143 Etobi, Ontario Jun 13, 2019 #2 @faran, Your cameras should be fine. Only the config on the NVR will be affected.
alastairstevenson Staff member Oct 28, 2014 16,234 7,008 Scotland Jun 13, 2019 #3 Assuming a hard reset from Hikvision as you don't know the admin password. As it's possible to do the hard reset yourself if you have the admin password - faran said: Sending this to my seller will this also reset the passwords for all camera. Click to expand... The camera passwords would then be orphaned. 58chev said: Your cameras should be fine. Only the config on the NVR will be affected. Click to expand... You will no longer know the password of the cameras if the NVR used its own password to activate them, which is the default. Here is an interesting little self-service trick to extract a forgotten or unknown NVR password with PoE ports : Alternative way of recovering HikVision NVR password
