I'm pretty much a newbie to IP cams.
I've just installed a cheap Zmodo 4ch 1tb some distance from any buildings. I've run electricity to the site and a wifi bridge hooks it to my LAN. I plan on putting it in a weather proof box. I need to adjust the configuration remotely and, hopefully, be able to control and monitor just as if I had access to it's HDMI output. The Zmodo does have a web server and does respond when I point a browser on my LAN to it. But, after a login, nothing but a blank screen. I find Zmodo support below useless. The NVR does do cloud stuff ok though I remain confused at the plethora of Zmodo apps: Zsight, Zmodo, MeShare and their purposes.
So, I'm shopping for a NVR that will serve my needs and ask for suggestions. Maybe something that runs X and would give me a window in response to a "ssh -XC <IP>" login.
OH! I run an all Linux LAN. Also, I have limited internet bandwidth and would like to minimize my cloud use.
