hi there,
i was just wondering if it would be possible to do change the NVR's POE Switch Network Address range to match those of my routers and then connect a cable from a port on the NVR switch directly to the router (Not the NVR LAN port). Basically treating the NVR POE switch as if it was a separate switch. The main reason why I was thinking of something like this is because I want to be able to access my cameras using the web interface as some features are missing from the NVR and it's not convenient for me to run a cable from the NVR to my laptop.
thanks
thanks
