- Sep 3, 2015
- 3
- 0
I recently purchased a gun safe that has 2 USB's and a RJ45 pass though as well as 120V. I haven't yet decided between a NVR or a computer with Blue Iris. Could I simply put the computer or the NVR inside the safe or would I need to leave them outside and somehow mirror a hard drive in the safe.
My Googling has found 2 arguments pro and con about this. One is that it would generate too much heat and the other argument is that you put a heating rod in there anyway to remove humidity and prevent rust so it may as well be a computer/NVR generating that heat.
I've checked the forums here and haven't found much regarding this. I was wondering if anyone else is actually storing their data inside their gun safe and how they are doing it.
As always thanks for the advice
