So i have had loads of issues since first installing a DS-2CD2342WD-i 4mp cam and a DS-7604NI-E1 4P/A NVR
When first installed the NVR was updated to the latest firmware 3.4.0 150929 and the 4mp cam had exposure flashing issues which Hikvision then released an update that resolved the flashing 5.3.3 150826
It definitely now appears that somewhere something is not right, using the camera web interface, changing settings for motion on the camera does not get reflected or saved onto the NVR settings
sensitivity is reflected from NVR to cam BUT
NVR sensitivity 1 = cam sensitivity 20
NVR sensitivity 2 = cam sensitivity 40
NVR sensitivity 3 = cam sensitivity 60
NVR sensitivity 4 = cam sensitivity 80
NVR sensitivity 5 = cam sensitivity 100
Why different numerations ?? use one or the other but not both also NVR sensitivity 3 i would assume to be half way between 1 and 5 so why is it 60 bearing in mind cam sensitivity can go to 0 when NVR cannot ?
If i change anything on the camera i am just realizing, the NVR does not reflect the settings
Intrusion detection from NVR setting to camera does not reflect on camera, trigger channel when set on NVR does not enable trigger channel on camera, this has to be done via the cam web interface
There are other inconsistencies and i am annoyed they are there but freaking glad i have finally found them, i was going mad trying to figure why i was getting so many false alarms when everything seemed to be set correctly via the NVR web interface...
the damned firmware's DO NOT WORK PROPERLY TOGETHER HIKVISION <----- Read and correct your mistakes by proper testing
WDR when turned on in the camera is unusable, even with setting low the image is washed out, WDR cannot be found in the NVR settings ??
A host of camera settings are not surfaced in the NVR web interface ?? again another Hikvision inconsistency
has anyone else found these issues ??
