- Dec 2, 2015
- 719
- 251
So, due to the different ranges of ip addresses and subnets provided by different internet provider ( IE comcast vs verizon etc ) I typically leave everything on DHCP until I have everything working on the network and then just change everything over to static with the current settings. I understand this may be a sloppy way to do this as the ip addresses will be typically all over the place.
I would like to start setting up static ips and subnets while bench testing but my knowledge of networking is pretty basic. So i'm hoping you guys can verify I have this correct.
Say the static IP address of the gateway is 50.212.10.1
I would/could then set the NVR IP to 50.212.1.250
and set all cameras to 50.212.1.1 - 50.212.1.249
With this configuration I would still have the ability to access the nvr and cameras through a networked computer without the need to modify my NIC IP correct?
I guess what I am really asking is am I ok as long as I only edit the last two segments for example, anything after the 50.212.
