S Scale Getting the hang of it Apr 14, 2020 150 17 . Apr 14, 2021 #1 Hi Everyone, My NVR NVR5416-16P-4KS2E incorrectly define my IPC-HDW5442TMP-ASE camera. It shows this camera type as just IP Camera. Before I used the camera IPC-HDW5442TM-AS and it was defined correctly. Could you tell me what it is? Regards, Denis Attachments 1.png 49.1 KB · Views: 18
wittaj IPCT Contributor Apr 28, 2019 32,901 62,970 USA Apr 14, 2021 #2 As long as it is working properly, I wouldn't be concerned about it. Could just be the way that particular camera is keyed in on the firmware.
S Scale Getting the hang of it Apr 14, 2020 150 17 . Apr 15, 2021 #3 wittaj said: As long as it is working properly, I wouldn't be concerned about it. Could just be the way that particular camera is keyed in on the firmware. Click to expand... Thank you! As I can see the camera works properly, but it looks a bit strange.
