Try a reboot of the NVR.
And if they don't show after that, confirm that the IP address of the NVR is the same subnet of the cameras, which I would think they would be if the NVR found them.
Yes you could factory reset the cameras from the camera GUI - open up a browser (preferably IE or Edge with IE tab) and type in the IP address of a camera and the login screen will pop up.
But before you do that, delete all the cameras from the NVR and add cameras back one at a time. Do not move to the next camera until the camera shows up.
