NVR Hard Drive Sizes
OICU2
BIT Beta Team
Jan 12, 2016
921
1,663
USofA
If using more then one HD in an NVR, is it recommended to keep the drives the same size? I would assume they should also be the same manufacturer and model as well.
Hi @OICU2
Different sized HDDs is OK in an NVR. Just double check the specs for the max HDD size, and look at what others have added. ( sometimes you can add a larger HDDs than the spec sheet indicates, sometimes the spec sheet is accurate.. so do double check )
Hi @OICU2
Thanks, I have the Hik DS-7616NI-E2. Spec sheet says 2 HD total, 6TB max in each. Anyone using bigger ? Or maybe one can get away with 12TB total, using 4TB in one and 8TB in another?
I learned something there. Always thought they had to be same size... ThX!
8TB each max. didn't know about the 10TB
If using multiple drives in a raid array, you’d want to use the same size, type and manufacturer. If just a couple of standard config drives, anything within spec will do.
Don’t exceed the drive capacity guidelines or your drives won’t be recognized as their full capacity. (If you place an 8TB in a NVR with 6TB max, it will only recognize as a 6TB. -A waste of money.
WD Purple was mentioned - good drives. Seagate Skyhawk drives are excellent and are better choices currently. (The two manufacturers seem to flip-flop every few years as the best drives on the market)
FYI - typically not creating an RAID ( 0, 1, or other ) on an NVR that holds 2 HDD
Reactions: The_E
Also, avoid Seagate at all cost, just sayin' ;)
Anecdotal experience has me under the impression that Seagate has regained top status. Curious why you avoid Seagate? (I would have wholeheartedly agreed with you 4-5 years ago). The only defective NVR drives I’ve had to replace In recent years have been WD Purples.
Reactions: Arjun
What Seagate lineup are you referencing? I had a bad experience with the Barracudas
