NVR export parameter
J273
May 22, 2016
84
21
I need to replace my current NVR due to a POE port failure and going to replace it with the same model (7616-NI I2)
The export parameter setting does this backup everything on the NVR including PTZ , schedule setting or will I need to re-sat up those once I restore the backup?
Thanks
If the firmware is different, most likely some components wont be restored.
You may as well try, if it doesnt work, you go as per usual.
