Im using NVR with FreeNAS. I have 2 more NVR's in the local network: DS-7604NI-E1/4P and DS-7608NI-E2/8P
Shares on freeNAS are OK. 3 shares 1 share for every nvr. Only the first one DS-7608NI-I2/8P cannot format the share. If i put this share on others - they do format it but not this one. I've tried to trick it - to format from other nvr and use with this one. It shows as Normal then but in some minutes the NVR restarts itself. No logs no nothing. If i remove the NAS disk all is perfect. Unformatted cant be formated, formatted from other nvr seems cant be used as it restarts itself every 5-10 mins.
Firmware version of the problematic NVR: v3.4.92 Build 170228
With regulard HDD inserted - it works good, the problem is with NAS.
P.S. The problem is NOT in the share because its working with the other nvrs. I think it might be a firmware problem.
P.S.S. Tried with different share size. Even with 100mb - same shit.
Waiting for your opinions.
Thank u.
Thank u.
